Einleitung
This guide will teach you how to replace defective buttons. You may need to clean under the buttons if you have sticky buttons.
Was du brauchst
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
Once separated, set aside the top panel.
5 weitere Personen haben diese Anleitung absolviert.
