Einleitung
This guide will show you the steps on installing the motherboard. This will be helpful if the controller won't turn on or if it turns on and doesn't work.
Was du brauchst
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
Once separated, set aside the top panel.
Using tweezers remove the three grey button pads from the motherboard.
With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
6 weitere Personen haben diese Anleitung absolviert.
