Einleitung
Use this guide to replace the power board on your Nintendo Wii mini.
Was du brauchst
Remove the two rubber feet at the back of the console to reveal the hidden screws.
Remove the four 6mm Phillips #0 screws.
Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
Gently lift the top piece of the console and set it aside.
Using your fingers, slide out the blue ribbon cable from the the top of the power board.
Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
