Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace a damaged front LCD display on your Nokia 6085H.
The front LCD display is the screen that displays the images of your phone. When an LCD display is damaged or broken, the screen may have a blank white or blue screen. If your screen has been cracked, it may display a white or blue screen with black lines running across. Before starting this guide, check out the Nokia 6085H Troubleshooting page.
If replacement of the front LCD display does not restore your screen, this may indicate an issue with the inner LCD display.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip over the phone so the back is facing upwards.
    • Flip over the phone so the back is facing upwards.
    • Press your thumb on the back cover and slide it off the phone.
  2. Remove the battery from the phone by hand.
    • Remove the battery from the phone by hand.
  3. With the phone closed, run a plastic opening tool along the seam of the top half of the phone. Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top). Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top).
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top).
  4. Using the T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel. Note that the fourth screw is under a fold in the ribbon cable.
    • Using the T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel.
    • Note that the fourth screw is under a fold in the ribbon cable.
  5. Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down. Be careful around the two ribbon cables attached to the tape. These cables are fragile. Lift the tape from the board.
    • Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board.
    • Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Brett Balcer
240 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-46, Amido Fall 2010 Mitglied von Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 24
Insgesamt: 843
