Einleitung
After many attempts of pushing the buttons, and failing to get a response. It may be time to replace your malfunctioning volume and power buttons. This repair guide has qualities required for your particular repair needs for the Nokia 520.
Was du brauchst
Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
Insert the spudger into the space between the batter and the battery holder to remove the battery.
Unscrew the 8 screws with a Torx screw driver (T4). After all screws are unscrewed place them next to the phone in the order
Use your spudger to remove the plastic casing over the motherboard. Do it very slowly because it will be tough to remove and you do not want to break it.
Carefully unclip the digitizer touch screen cable and the display screen cable using a spudger.
Gently remove the motherboard with your hands.
Flip it over and turn it 90 degrees to the left so the buttons are in front of you.
Gently take the power/volume switches off using a pair of needle nose pliers. Gently clean the solder that was there. Replace the solder with a new coat of solder.
4 weitere Personen haben diese Anleitung absolviert.
