Einleitung
Use this guide to replace the switch if the device will not turn on when receiving power.
Was du brauchst
First, place the device on its side, making sure the switch is not facing down.
Remove the eight 12mm Phillips #02 screws from the base.
Using a pair of pliers, firmly grip the base of the wire.
Pull the wire straight out of the switch.
Repeat this step for each wire.
Using pliers, pinch tabs at the top and bottom of switch.
While pinching the tabs, push the switch until the tabs are on the outside of the device.
Ein Kommentar
The red light turns on but the disk isnt spinning or heating up and when the out let has power
