Zum Hauptinhalt wechseln
Nostalgia Electrics PCM805 Power Switch Replacement
Was du brauchst
  1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: Schritt 1, Bild 1 von 2 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: Schritt 1, Bild 2 von 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 2, Bild 1 von 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: Schritt 3, Bild 1 von 1
    • Locate the switch/wire assembly inside the device.
  4. Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 4, Bild 1 von 1
    • Pull back the insulation sleeves to expose the connector heads.
  5. Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 5, Bild 1 von 2 Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 5, Bild 2 von 2
    • Note the color of each wire and the order you remove them.
    • Using a pair of pliers, firmly grip the base of the wire.
    • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
    • Pull the wire straight out of the switch.
    • Repeat this step for each wire.
  6. Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 6, Bild 1 von 2 Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 6, Bild 2 von 2
    • Using pliers, pinch tabs at the top and bottom of switch.
    • While pinching the tabs, push the switch until the tabs are on the outside of the device.
  7. Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 7, Bild 1 von 2 Nostalgia Electrics PCM805 Power Switch Replacement: Schritt 7, Bild 2 von 2
    • Remove the switch from the device.
Abschluss
Carlton
672 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 3-5, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 1,948
