Zum Hauptinhalt wechseln
NuWave Brio 37001 Basket Handle Replacement
Was du brauchst
  1. NuWave Brio 37001 Basket Handle Replacement, Basket Handle: Schritt 1, Bild 1 von 1
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket from the NuWave's tray.
    • After removing the basket, push forward on the handle tab and pull upwards to release the basket from its casing.
  2. NuWave Brio 37001 Basket Handle Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 10 mm screws connecting the handle to the basket using a Phillips #1 screwdriver.
  3. NuWave Brio 37001 Basket Handle Replacement: Schritt 3, Bild 1 von 2 NuWave Brio 37001 Basket Handle Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 6 mm screws arranged in a rectangle around the handle using a Phillips #1 screwdriver.
    • Remove two 12 mm screws just below the previous four using a Phillips #1 screwdriver.
    • The two 12 mm Phillips #1 screws are in a tight spot and may be tricky to remove.
  4. NuWave Brio 37001 Basket Handle Replacement: Schritt 4, Bild 1 von 1
    • Separate the metal bracket from the handle.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Where do you get just the replacement handle?
lucy montgomery - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 29
Insgesamt: 410
