Zum Hauptinhalt wechseln
NuWave Brio 37001 Rubber Feet Replacement
  1. NuWave Brio 37001 Rubber Feet Replacement, Rubber Feet: Schritt 1, Bild 1 von 2 NuWave Brio 37001 Rubber Feet Replacement, Rubber Feet: Schritt 1, Bild 2 von 2
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket, and flip the air fryer upside down so its feet are accessible.
  2. NuWave Brio 37001 Rubber Feet Replacement: Schritt 2, Bild 1 von 2 NuWave Brio 37001 Rubber Feet Replacement: Schritt 2, Bild 2 von 2
    • Using gentle force, pull out the damaged leg or legs.
    • If you are unsure which leg or legs need replacement, try flipping the air fryer back over again. If the legs are uneven, the air fryer will rock diagonally. The bad leg is one of the two corners that go up and down when it rocks.
    • If you still have the original packaging, the air fryer may have come with a sachet of replacement feet.
Abschluss
If your Air Fryer is still unbalanced, identify the additional bad leg and repeat the process!
Eine weitere Person hat diese Anleitung absolviert.
Ian Moore
115 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 117
