Einleitung
This will be a step-by-step guide to remove the battery assembly from the Nvidia Shield. This will need to be performed to install a new battery into the device. The user will not need any special skills beforehand to successfully remove the battery. The user can put the device back together with a new battery installed by following the steps in reverse. Replacing the battery in a Nvidia Shield can help improve the quality of the battery life of the product. If you notice the battery swelling or smoking, before proceeding check out the guide for what to do with a swollen battery.
Ersatzteile
Keine Ersatzteile angegeben.
Unscrew the 7 6.4mm T5 Torx screws from back panel
Use spudger to separate front and back panels
Remove the six 6.5mm T5 Torx screws.
Remove power wires.
Peel back copper tape and remove black and white wires.
Pull the battery apparatus out once all cables are removed.
2 weitere Nutzer haben diese Anleitung absolviert.
