Einleitung
Use this guide to replace a damaged back case, or open the case to access other components of your camera.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Ersatzteile
Keine Ersatzteile angegeben.
Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
Flip open the LCD.
Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
Press and hold the lens release button while using tweezers to remove the lens hook.
Use tweezers to remove the spring underneath the lens hook.
Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
Remove the 2 mm Phillips screw.
Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
3 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
