Einleitung
Is your LCD Screen cracked or unresponsive? Use this guide to replace it and get back to taking awesome photos.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Was du brauchst
Turn the camera upside down.
Push the grey tab to the right to open the battery compartment.
Pull out the battery.
Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
Use tweezers to remove the top LCD bracket.
Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
Remove the LCD ribbon cable with a pair of tweezers.
6 weitere Personen haben diese Anleitung absolviert.
10 Kommentare zur Anleitung
Magnifico
Great Work!!
Where can I buy a replacement LCD screen?
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
