Einleitung
This guide will show you how to replace the external lens assembly on the Olympus E-PL7.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Was du brauchst
Turn the camera upside down.
Push the grey tab to the right to open the battery compartment.
Pull out the battery.
Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
Remove the lens mount with tweezers.
Use a Phillips #00 screwdriver to remove the three 5 mm screws.
Remove the two 4 mm Phillips screws.
Press and hold the lens release button while using tweezers to remove the lens hook.
Use tweezers to remove the spring underneath the lens hook.
To reassemble your camera, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
