Einleitung
This prerequisite guide for the One Education: Infinity showcases the process of disconnecting the display assembly from the upper portion of the hinge mechanism for removal.
Additionally, note that this guide has the user remove the battery prior to disassembling the upper case to prevent any electrical damage while disconnecting the display cables. However, the same effect can be achieved by simply disconnecting the battery cable, so the battery removal in step 5 can be skipped to save a bit of time and effort.
Was du brauchst
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
Lift the back case off of the device.
Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
Lift the battery out from the internal case.
Flip open the laptop so that the screen is exposed.
Using a spudger, remove the six screw covers along the bezel of the screen.
Use the two tabs on the top edge of the screen to pry the case apart.
Once the two top clips have been disengaged, start to work your way around the rest of the screen.
Once all the clips have been popped off, remove the upper case from the back of the display assembly.
Remove the twelve 3.8 mm Phillips #00 screws from the hinge brackets extending along the height of the display.
Peel back the four pieces of black tape.
Peel back the antenna cable boards off of the display hinges.
Peel off the silver tape from the display hinges.
