Zum Hauptinhalt wechseln
OnePlus 6 Midframe Replacement
Was du brauchst
  1. OnePlus 6 Midframe Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Midframe Replacement: Schritt 2, Bild 1 von 2 OnePlus 6 Midframe Replacement: Schritt 2, Bild 2 von 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Midframe Replacement: Schritt 3, Bild 1 von 2 OnePlus 6 Midframe Replacement: Schritt 3, Bild 2 von 2
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Midframe Replacement, Battery: Schritt 4, Bild 1 von 2 OnePlus 6 Midframe Replacement, Battery: Schritt 4, Bild 2 von 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Midframe Replacement, Midframe: Schritt 5, Bild 1 von 2 OnePlus 6 Midframe Replacement, Midframe: Schritt 5, Bild 2 von 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the screw at the bottom left is marked wrong in this picture. The actual 10th screw is actually underneath the round white sticker. Do not remove the screw marked at bottom left, but strip over the white sticker which has a screw underneath it. Otherwise you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Clemson, Team 4-3, Hunter Fall 2021 Mitglied von Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 1,231
