Einleitung
This guide will show how to replace the motherboard of your OnePlus 6T. Make sure to use the correct tools and to be careful after removing the back cover of the device.
Was du brauchst
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
Carefully remove the SIM card from its tray.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
Use tweezers to remove the battery cover and place it to the side.
Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
Remove the front camera from the phone.
Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
Use a spudger to disconnect the signal cables on the right side of the motherboard.
Disconnect the slider from the top of the phone with a spudger.
Gently pull the motherboard from the left side and remove it from the phone.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
