Zum Hauptinhalt wechseln
Ozeri Pronto ZK14-S LCD Motherboard Replacement
Was du brauchst
  1. Ozeri Pronto ZK14-S LCD Motherboard Replacement, Panel Removal: Schritt 1, Bild 1 von 2 Ozeri Pronto ZK14-S LCD Motherboard Replacement, Panel Removal: Schritt 1, Bild 2 von 2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 4, Bild 1 von 2 Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 5, Bild 1 von 2 Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 9, Bild 1 von 2 Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Motherboard Replacement, LCD Motherboard: Schritt 10, Bild 1 von 1
    • Stand the center motherboard up.
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
  11. Ozeri Pronto ZK14-S LCD Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Unsolder the posts to remove the wires
    • Repeat this step to remove the other two motherboards
Abschluss
Oneika White
709 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-4, Leahy Fall 2015 Mitglied von USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 487
