Zum Hauptinhalt wechseln
Pacific Image Electronics CS3600 Motor Replacement
Was du brauchst
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: Schritt 1, Bild 1 von 2 Pacific Image Electronics CS3600 Motor Replacement, Motor: Schritt 1, Bild 2 von 2
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: Schritt 2, Bild 1 von 1
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: Schritt 3, Bild 1 von 1
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: Schritt 4, Bild 1 von 2 Pacific Image Electronics CS3600 Motor Replacement: Schritt 4, Bild 2 von 2
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: Schritt 5, Bild 1 von 1
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Abschluss
Alessia Carlton
201 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S46-G2, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G2, Bennett Spring 2017
TTU-BENNETT-S17S46G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 226
