Einleitung
This guide will tell you how to gain access to and remove the motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
Push and slide the latch up to open the hard drive door.
Pull out the hard drive.
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Remove the black and white wires attached to the wireless card by simply pulling up.
Using a pair of plastic opening tools, push the two metal tabs away from the card.
The wireless card should now easily disengage from the motherboard.
Pull the card horizontally away from you to remove it from its housing.
Unplug 3 cables
Lift up on brown tab to release cable
Pull cable up and out
Remove 2 long screws indicated with red circles
Remove the remaining screws indicated in blue
On the back of the unit, unscrew the three screws surrounding the serial port.
Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
5 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
what about spare parts? is it possible cange MOBO and CPU? in order to upgrade the thoughbook?
