Zum Hauptinhalt wechseln
Panasonic VDR-D220 DVD Battery Replacement
Was du brauchst
  1. Panasonic VDR-D220 DVD Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release lever found on the bottom of the camera in the direction of the front of the camera.
  2. Panasonic VDR-D220 DVD Battery Replacement: Schritt 2, Bild 1 von 2 Panasonic VDR-D220 DVD Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery from its holding spot/where it mounts to the camera.
    • Inspect the contact points and be sure that there isn't any debris that could be resulting in loss of current flow.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 26
Insgesamt: 554
