Einleitung
Dropped your camera, or forgot to put the lens cover back on then your lens is damaged. Any scratches or chips in a lens will alter your most valuable moments and leave you with an imperfect image. This guide will show you how to restore the quality of camera you deserve.
Was du brauchst
Remove one 5mm screw on the bottom side of the camera with a Phillips #0 screwdriver.
Using a plastic spudger, pry to disconnect the top-front part of the camera.
Slide the top portion of the camera forward revealing a ribbon cable.
Flip the camera on the right side.
Gently pull the front part from the main body to reveal the cables connecting them.
Use your plastic opening tool to disconnect the connection point safely.
Press the tab with a plastic opening tool and then pull the ZIF connector to detach.
Look at the camera from the front side.
Remove four 5mm screws using a Phillips #0 screwdriver.
