Zum Hauptinhalt wechseln
Panasonic VDR-D220 DVD LCD Replacement
Was du brauchst
  1. Panasonic VDR-D220 DVD LCD Replacement, LCD: Schritt 1, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement, LCD: Schritt 1, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement, LCD: Schritt 1, Bild 3 von 3
    • Remove all three 5mm screws from the top of the camera using a Phillips #0 screwdriver.
  2. Panasonic VDR-D220 DVD LCD Replacement: Schritt 2, Bild 1 von 2 Panasonic VDR-D220 DVD LCD Replacement: Schritt 2, Bild 2 von 2
    • Rotate the camera to show the bottom side of the camera.
    • Remove the four 5mm screws on the bottom side of the camera with a Phillips #0 driver.
  3. Panasonic VDR-D220 DVD LCD Replacement: Schritt 3, Bild 1 von 2 Panasonic VDR-D220 DVD LCD Replacement: Schritt 3, Bild 2 von 2
    • Remove one 5mm screw by using Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD LCD Replacement: Schritt 4, Bild 1 von 2 Panasonic VDR-D220 DVD LCD Replacement: Schritt 4, Bild 2 von 2
    • Pry with a spudger to disconnect the top-front part of the camera from the main body.
    • Slide the top portion of the camera forward revealing more screws.
    • Be careful not to remove the two sections too far as there are still cables connecting them.
  5. Panasonic VDR-D220 DVD LCD Replacement: Schritt 5, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 5, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 5, Bild 3 von 3
    • Flip the camera on the right side.
    • Gently pull the front part from the main body to expose the cables connecting them.
    • Do not pull too hard because of the ZIF connector cable.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD LCD Replacement: Schritt 6, Bild 1 von 1
    • Flip the camera on the bottom side.
    • Remove one more 5mm screw that had been uncovered previously with a Phillips #0 screwdriver.
  7. Panasonic VDR-D220 DVD LCD Replacement: Schritt 7, Bild 1 von 2 Panasonic VDR-D220 DVD LCD Replacement: Schritt 7, Bild 2 von 2
    • Go to the battery basement's side.
    • Use your Phillips #0 screwdriver to remove the two 5mm screws on the battery base of the camera.
  8. Panasonic VDR-D220 DVD LCD Replacement: Schritt 8, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 8, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 8, Bild 3 von 3
    • Rotate the camera to the left side, where the side port is located.
    • Open the side port door.
  9. Panasonic VDR-D220 DVD LCD Replacement: Schritt 9, Bild 1 von 1
    • Remove three 5mm screws inside the side ports using Phillips #0 screwdriver.
    • Take off the left side of the camera.
  10. Panasonic VDR-D220 DVD LCD Replacement: Schritt 10, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 10, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 10, Bild 3 von 3
    • Rotate the camera to the battery side.
    • Gently pull the side of the camera apart with only your hands.
    • Disconnect the ribbon cable with your plastic opening tool, so that the left side of the camera can be removed.
  11. Panasonic VDR-D220 DVD LCD Replacement: Schritt 11, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 11, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 11, Bild 3 von 3
    • Look to the left side of the camera you have removed.
    • The back side of the left side of the camera.
    • Remove six 5mm screws with your Phillips #0 screwdriver.
  12. Panasonic VDR-D220 DVD LCD Replacement: Schritt 12, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 12, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 12, Bild 3 von 3
    • Take off the metal piece.
    • Use your plastic opening tool to disconnect the ribbon cable. Press the tab with plastic opening tool and then pull the ZIF connector to detach.
  13. Panasonic VDR-D220 DVD LCD Replacement: Schritt 13, Bild 1 von 1
    • Use a plastic spudger to apply a firm amount of pressure to pry the hinge from the rest of the camera body.
  14. Panasonic VDR-D220 DVD LCD Replacement: Schritt 14, Bild 1 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 14, Bild 2 von 3 Panasonic VDR-D220 DVD LCD Replacement: Schritt 14, Bild 3 von 3
    • Go back to the back side.
    • Take off the small plastic piece.
    • Pay attention to the ribbon cable because it goes through the plastic piece.
    • Rotate the right side of the LCD counter clockwise.
    • Left side of the camera after LCD is removed.
  15. Panasonic VDR-D220 DVD LCD Replacement: Schritt 15, Bild 1 von 2 Panasonic VDR-D220 DVD LCD Replacement: Schritt 15, Bild 2 von 2
    • LCD replacement part.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 296
