Zum Hauptinhalt wechseln
Philips DPM8000 Speaker Replacement
Was du brauchst
  1. Philips DPM8000 Speaker Replacement, Anti-Static Wrist Strap: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    $7.95
    Kaufen
    • Before you start disassembling your device make sure that it is turned off.
    • Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpainted spot of a radiator.
  2. Philips DPM8000 Speaker Replacement, Battery Lid: Schritt 2, Bild 1 von 2 Philips DPM8000 Speaker Replacement, Battery Lid: Schritt 2, Bild 2 von 2
    • Remove the battery lid
  3. Philips DPM8000 Speaker Replacement, Battery: Schritt 3, Bild 1 von 2 Philips DPM8000 Speaker Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the battery.
    • The battery lid is designed to function as an instrument for this task.
  4. Philips DPM8000 Speaker Replacement, Upper Ornamental Part: Schritt 4, Bild 1 von 3 Philips DPM8000 Speaker Replacement, Upper Ornamental Part: Schritt 4, Bild 2 von 3 Philips DPM8000 Speaker Replacement, Upper Ornamental Part: Schritt 4, Bild 3 von 3
    • Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
    • Collect the removed screws in a bowl or something comparable, otherwise they might get lost.
  5. Philips DPM8000 Speaker Replacement: Schritt 5, Bild 1 von 3 Philips DPM8000 Speaker Replacement: Schritt 5, Bild 2 von 3 Philips DPM8000 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Remove the upper ornamental part from the housing.
    • If your fingernails are not long enough you can use a plastic opening tool.
    • When reassembling the device be aware that the six shackles on the sides of the upper ornamental part need to be placed inside the frame.
  6. Philips DPM8000 Speaker Replacement, Housing/Display: Schritt 6, Bild 1 von 2 Philips DPM8000 Speaker Replacement, Housing/Display: Schritt 6, Bild 2 von 2
    • Lift up the housing.
    • The display as well as the speaker are connected to the motherboard. Therefore you need to be careful not to harm those connections.
  7. Philips DPM8000 Speaker Replacement: Schritt 7, Bild 1 von 2 Philips DPM8000 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Unlock the connection between display and motherboard by pushing open the brown cleat.
    • It is recommended to use a spudger or a comparable tool for this step.
    • If the connection is not completely open, one of the involved components could easily be harmed.
  8. Philips DPM8000 Speaker Replacement: Schritt 8, Bild 1 von 2 Philips DPM8000 Speaker Replacement: Schritt 8, Bild 2 von 2
    • Separate the connection by pulling out the display cable.
    • If the cable does not come out easily, the connection is probably still locked.
    • When reconnecting the display to the motherboard don't forget to lock the connection, otherwise it will eventually come loose and you will have to redo the first eight steps of this guide.
  9. Philips DPM8000 Speaker Replacement, Speaker: Schritt 9, Bild 1 von 3 Philips DPM8000 Speaker Replacement, Speaker: Schritt 9, Bild 2 von 3 Philips DPM8000 Speaker Replacement, Speaker: Schritt 9, Bild 3 von 3
    • Remove the mounting spring from the speaker with a pair of tweezers.
    • If you just want to replace the motherboard, it is recommended to ignore the steps 9 and 10.
  10. Philips DPM8000 Speaker Replacement: Schritt 10, Bild 1 von 2 Philips DPM8000 Speaker Replacement: Schritt 10, Bild 2 von 2
    • Take off the safety mat from the speaker.
    • Remove the speaker from the housing.
  11. Philips DPM8000 Speaker Replacement, Motherboard: Schritt 11, Bild 1 von 2 Philips DPM8000 Speaker Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Unscrew the eight Torx #4 (5,0 mm) screws from the motherboard.
    • These two screws connect the motherboard with the sliding cage. In this guide they are removed as well. Hence this is not compulsory you can decide for yourself whether you want to remove them now or later.
  12. Philips DPM8000 Speaker Replacement: Schritt 12, Bild 1 von 2 Philips DPM8000 Speaker Replacement: Schritt 12, Bild 2 von 2
    • Push in the SD-Card to eject it.
    • If the memory card remains in its slot you will not be able to remove the motherboard.
  13. Philips DPM8000 Speaker Replacement: Schritt 13, Bild 1 von 2 Philips DPM8000 Speaker Replacement: Schritt 13, Bild 2 von 2
    • Abstract the motherboard.
    • Lift up the motherboard as shown in the picture before completely removing it.
    • When inserting the motherboard first put in the side with the speaker jack on it and make sure that the microphone is placed properly under the motherboard.
  14. Philips DPM8000 Speaker Replacement, Speaker: Schritt 14, Bild 1 von 2 Philips DPM8000 Speaker Replacement, Speaker: Schritt 14, Bild 2 von 2
    • Preheat your soldering equipment.
    • Dissolve the soldering connection between motherboard and defective speaker.
    • You can use a pair of tweezers for this step but your fingers will do it as well.
    • For further informations on soldering please refer to this guide.
  15. Philips DPM8000 Speaker Replacement: Schritt 15, Bild 1 von 1
    • Solder the new speaker to the motherboard.
Abschluss
To reassemble your device, follow these instructions in reverse order beginning with step 13.
Andreas Holl
731 Reputation
6 Anleitungen geschrieben
Technische Universität Wien Mitglied von Technische Universität Wien
Community
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 263
