Zum Hauptinhalt wechseln
Philips Norelco 5801XL Battery Replacement
Was du brauchst
  1. Philips Norelco 5801XL Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Philips Norelco 5801XL Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: Schritt 2, Bild 1 von 2 Philips Norelco 5801XL Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: Schritt 3, Bild 1 von 3 Philips Norelco 5801XL Battery Replacement: Schritt 3, Bild 2 von 3 Philips Norelco 5801XL Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: Schritt 5, Bild 1 von 1
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: Schritt 7, Bild 1 von 3 Philips Norelco 5801XL Battery Replacement: Schritt 7, Bild 2 von 3 Philips Norelco 5801XL Battery Replacement: Schritt 7, Bild 3 von 3
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ben Gibbs
361 Reputation
3 Anleitungen geschrieben
IUPUI, Team 3-2, Harley Spring 2016 Mitglied von IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
4 Mitglieder
6 Anleitungen geschrieben
3 Kommentare
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Antwort
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 4,374
