Einleitung
This guide will show you how to replace the circuit board for the Philips Sonicare 2 Series toothbrush. He is a link for a guide how to soldering which will be needed for this guide. Wie man Lötverbindungen herstellt und entlötet
  1. Remove brush on top of device.
    • Remove brush on top of device.
  2. Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
    • Remove the white battery cover as shown in the figure.
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
    • Pry away the battery using an opening tool from the battery housing. This will break the circuit and avoid electric shock.
    • Desolder the circuit board from the motor as shown.
    • Desolder the circuit board from the housing as shown to remove the board
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jonathan Jarvis
Mitglied seit 01.04.2016
452 Reputation
4 Anleitungen geschrieben
IUPUI, Team S6-G2, Baechle Fall 2017 Mitglied von IUPUI, Team S6-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G2
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 237
