Was du brauchst
Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
Remove the internals from the casing.
Carefully free the top end of the circuit board from the plastic clips holding it in place.
Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
Remove the circuit board.
Fast fertig!
Abschluss
