Zum Hauptinhalt wechseln
Photive Hydra Bluetooth Connector Replacement
Was du brauchst
  1. Photive Hydra Bluetooth Connector Replacement, Face Plate and Back Plate: Schritt 1, Bild 1 von 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Bluetooth Connector Replacement: Schritt 2, Bild 1 von 2 Photive Hydra Bluetooth Connector Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Bluetooth Connector Replacement: Schritt 3, Bild 1 von 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Bluetooth Connector Replacement: Schritt 4, Bild 1 von 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Bluetooth Connector Replacement: Schritt 5, Bild 1 von 2 Photive Hydra Bluetooth Connector Replacement: Schritt 5, Bild 2 von 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Bluetooth Connector Replacement, Battery (Prerequisite): Schritt 6, Bild 1 von 2 Photive Hydra Bluetooth Connector Replacement, Battery (Prerequisite): Schritt 6, Bild 2 von 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Bluetooth Connector Replacement: Schritt 7, Bild 1 von 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra Bluetooth Connector Replacement, Bluetooth Connector: Schritt 8, Bild 1 von 2 Photive Hydra Bluetooth Connector Replacement, Bluetooth Connector: Schritt 8, Bild 2 von 2
    • Identify the motherboard and the three Philips (Length-1/8,Head-1/8) screws and remove them using a #1 Phillips screwdriver.
  9. Photive Hydra Bluetooth Connector Replacement: Schritt 9, Bild 1 von 2 Photive Hydra Bluetooth Connector Replacement: Schritt 9, Bild 2 von 2
    • Pull the motherboard up and out to dislodge it.
    • Do not fully remove your motherboard to prevent any unwanted severing of connections.
  10. Photive Hydra Bluetooth Connector Replacement: Schritt 10, Bild 1 von 1
    • Identify the Bluetooth connector device.
  11. Photive Hydra Bluetooth Connector Replacement: Schritt 11, Bild 1 von 1
    • The two solder points shown are to be removed by use of a soldering gun. Remove and replace the component with a functioning connector device. Refer to the link below for soldering techniques. Wie man Lötverbindungen herstellt und entlötet
Abschluss
Matthew Knight
246 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 11-3, Cheng Spring 2016 Mitglied von USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
So any leads on where to get the module?
Charles - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 311
