Einleitung
Use this guide to replace a failed battery in the Photive Rain.
Was du brauchst
Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
Remove back panel
Remove the plastic cover in front of the battery slot.
Unscrew all the 8.5mm screws that hold the cover to the slot.
Separate the battery from the back panel as shown in photograph 3.
Remove the battery from the motherboard.
Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
