Einleitung
This guide will walk you through replacing the LED light ring and button panel. To completely separate the two from the device, you may need to know how to solder and desolder connections.
Was du brauchst
Flip the speaker upside down with the back panel of plugs pointed away from you.
Use the metal spudger to pry off the rubber bottom cover. It will be glued onto the bottom of the speaker.
Work the rubber cover off by slowly going all the way around with the metal spudger, applying as much force as needed.
Scrape most of the glue away to reveal the five flathead screws - four around the outside, and one in the middle.
Lift off the metal plate. It will be surprisingly heavy and it is approximately 1cm thick.
Turn the speaker counter-clockwise 90 degrees.
Use a knife to cut along the left seam all the way down the length of the device.
Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you.
Remove one 6 mm screw with a Phillips #2 screwdriver.
Spin the device so the opposite side is facing you.
Remove the two 6 mm screws with a Phillips #2 screwdriver.
Carefully remove the top panel, light ring, button panel, and the corresponding board.
Lay the speaker down flat to make it easier to work on.
Remove the seven 4 mm screws with a Phillips #2 screwdriver.
Gently pry the plastic light ring from the circuit board and button panel.
