Zum Hauptinhalt wechseln
Plantronics Voyager Legend Earpiece Replacement
Was du brauchst
  1. Plantronics Voyager Legend Earpiece Replacement, Earpiece: Schritt 1, Bild 1 von 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: Schritt 1, Bild 2 von 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: Schritt 1, Bild 3 von 3
    • Remove the soft, plastic earpiece.
    • Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
    • List the soft, plastic earpiece out of its position.
  2. Plantronics Voyager Legend Earpiece Replacement: Schritt 2, Bild 1 von 1
    • Heat the earpiece assembly with a heat gun (a hair dryer will work if a heat gun is not available).
    • The heating softens the adhesive that holds the assembly together, and the assembly may need to be reheated to complete the dis-assembly process.
  3. Plantronics Voyager Legend Earpiece Replacement: Schritt 3, Bild 1 von 2 Plantronics Voyager Legend Earpiece Replacement: Schritt 3, Bild 2 von 2
    • The two snaps that combine with the adhesive to hold the assembly together are located in the neck of the earpiece unit.
  4. Plantronics Voyager Legend Earpiece Replacement: Schritt 4, Bild 1 von 2 Plantronics Voyager Legend Earpiece Replacement: Schritt 4, Bild 2 von 2
    • Remove the top half of the earpiece assembly.
    • Use the pointed end of a small, metal Spudger to loosen the two tabs that hold the earpiece assembly together.
    • While glue is soft and snaps are loosened, remove the entire top half of the earpiece housing.
  5. Plantronics Voyager Legend Earpiece Replacement: Schritt 5, Bild 1 von 3 Plantronics Voyager Legend Earpiece Replacement: Schritt 5, Bild 2 von 3 Plantronics Voyager Legend Earpiece Replacement: Schritt 5, Bild 3 von 3
    • Remove the speaker housing.
    • With the copper backing plate displayed, use the pointed end of a small, metal Spudger to disassemble the speaker housing.
    • Using the pointed end of the small, metal Spudger, lift the copper, backing plate away from the speaker unit.
  6. Plantronics Voyager Legend Earpiece Replacement: Schritt 6, Bild 1 von 2 Plantronics Voyager Legend Earpiece Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use Precision Tweezers to remove the protective screen from the front of the speaker unit.
  7. Plantronics Voyager Legend Earpiece Replacement: Schritt 7, Bild 1 von 3 Plantronics Voyager Legend Earpiece Replacement: Schritt 7, Bild 2 von 3 Plantronics Voyager Legend Earpiece Replacement: Schritt 7, Bild 3 von 3
    • Remove the speaker unit and solder a new unit in place.
    • When disconnecting leads, always disconnect as near as possible to the component being replaced, to allow room for reattachment.
    • Locate the leads that connect to the back of the speaker unit.
    • Disconnect the leads from the back of the speaker unit.
    • Remove the speaker unit, and replace by soldering the leads back into their correct locations.
    • Refer to the iFixit soldering guide for assistance with soldering.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Lewis Certain
2.287 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015
USFSM-STEWART-F15S1G2
5 Mitglieder
17 Anleitungen geschrieben
Ein Kommentar
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
albert einstein - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 80
Insgesamt: 16,125
