Einleitung
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
More info about disassembling, you can find in
Was du brauchst
Einführungsvideo
Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
Remove the two very small phillips screws in each lower corner referenced by the red circles.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
