Einleitung
The rumble motor is the device that allows the move controller to vibrate. This guide will help you replace it if it is broken or damaged.
Was du brauchst
Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
Using your fingers, carefully pry the square green piece beneath the battery slot free.
Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
Lift the rectangular piece from its slot to free it.
Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
Ein Kommentar
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
