Zum Hauptinhalt wechseln
PlayStation Vita GPS Antenna Cable Replacement
Was du brauchst
  1. PlayStation Vita GPS Antenna Cable Replacement, Case Separation: Schritt 1, Bild 1 von 2 PlayStation Vita GPS Antenna Cable Replacement, Case Separation: Schritt 1, Bild 2 von 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita GPS Antenna Cable Replacement: Schritt 2, Bild 1 von 3 PlayStation Vita GPS Antenna Cable Replacement: Schritt 2, Bild 2 von 3 PlayStation Vita GPS Antenna Cable Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita GPS Antenna Cable Replacement: Schritt 3, Bild 1 von 2 PlayStation Vita GPS Antenna Cable Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita GPS Antenna Cable Replacement: Schritt 4, Bild 1 von 3 PlayStation Vita GPS Antenna Cable Replacement: Schritt 4, Bild 2 von 3 PlayStation Vita GPS Antenna Cable Replacement: Schritt 4, Bild 3 von 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita GPS Antenna Cable Replacement: Schritt 5, Bild 1 von 2 PlayStation Vita GPS Antenna Cable Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita GPS Antenna Cable Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita GPS Antenna Cable Replacement: Schritt 7, Bild 1 von 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita GPS Antenna Cable Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and rear cases.
  9. PlayStation Vita GPS Antenna Cable Replacement, GPS Antenna Cable: Schritt 9, Bild 1 von 1
    • Using the pointy end of the spudger, gently pry the GPS antenna cable off the wireless card.
  10. PlayStation Vita GPS Antenna Cable Replacement: Schritt 10, Bild 1 von 2 PlayStation Vita GPS Antenna Cable Replacement: Schritt 10, Bild 2 von 2
    • Using the pointy end of a spudger, gently pry the GPS antenna cable off of the motherboard.
    • Deroute the GPS antenna cable out of the casing and remove it.
Abschluss
Brittany McCrigler
89.739 Reputation
142 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.416 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 4,834
