Einleitung
If the speakers fail to properly play sound, consider using this guide to replace them.
Was du brauchst
Flip the device so that the screen faces down, with the back facing up.
Unscrew the four screws with a PH000 screwdriver.
Flip the device over so that the screen faces up, and the back faces down.
Separate the front panel using the Opening Tool on a corner to create an opening.
Run the tool along the seams of the device to open up all the sides.
Use the Opening tool to flip up the black retaining flap on the smaller connector.
Gently lift the cable, parallel to the panel, to detach it.
Use the Opening tool to flip up the black retaining flap on the larger connector.
Use the tweezers to lift the speakers out of its compartment, including the felt cover attached to the plastic.
Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
