Einleitung
This guide is for a Porter-Cable 20V Oscillating Multi-Tool with the model number: PCC710B. You'll need to follow this guide in order to open up the oscillating multi-tool and gain access to the internal parts.
If your device is experiencing issues that cannot be fixed with a simple cleaning or tightening of the tool's blades, you'll need to follow this guide to reach any malfunctioning parts.
Before beginning this guide, make sure the battery of the tool is taken off, you do not want any power source connected to the device while working on this replacement!
Was du brauchst
Place the tool on its side so the orange and white warning label barcodes are facing up.
The lever and battery base of the tool should point toward you.
Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
Lay the tool on its side so that the grey and orange warning labels are facing up upwards.
Use the JIS #1 screwdriver to remove the 10 screws holding the tool together.
