Zum Hauptinhalt wechseln
Porter-Cable PCE211 Fan Replacement
Was du brauchst
  1. Porter-Cable PCE211 Fan Replacement, Gearcase: Schritt 1, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Gearcase: Schritt 1, Bild 2 von 2
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
  2. Porter-Cable PCE211 Fan Replacement: Schritt 2, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 2, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 2, Bild 3 von 3
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
  3. Porter-Cable PCE211 Fan Replacement, Anvil: Schritt 3, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement, Anvil: Schritt 3, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement, Anvil: Schritt 3, Bild 3 von 3
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
  4. Porter-Cable PCE211 Fan Replacement, Motor: Schritt 4, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement, Motor: Schritt 4, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement, Motor: Schritt 4, Bild 3 von 3
    • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
    • Pull the motor out with your hands.
  5. Porter-Cable PCE211 Fan Replacement: Schritt 5, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 5, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 5, Bild 3 von 3
    • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
  6. Porter-Cable PCE211 Fan Replacement, Rear Housing: Schritt 6, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Rear Housing: Schritt 6, Bild 2 von 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  7. Porter-Cable PCE211 Fan Replacement: Schritt 7, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement: Schritt 7, Bild 2 von 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  8. Porter-Cable PCE211 Fan Replacement, Grip: Schritt 8, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Grip: Schritt 8, Bild 2 von 2
    • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
  9. Porter-Cable PCE211 Fan Replacement: Schritt 9, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement: Schritt 9, Bild 2 von 2
    • Pull the grip from the body of the impact wrench.
  10. Porter-Cable PCE211 Fan Replacement, Fan: Schritt 10, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Fan: Schritt 10, Bild 2 von 2
    • Lift the hammer block (which is attached to the fan) out of the case.
    • It is a little heavy so be careful when lifting it out.
  11. Porter-Cable PCE211 Fan Replacement: Schritt 11, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement: Schritt 11, Bild 2 von 2
    • If you're doing maintenance and the fan isn't damage, use a microfiber cloth to clean the fan.
    • Wipe well until there's no residue or oil lubricant.
Abschluss
Layla Berry
678 Reputation
7 Anleitungen geschrieben
Austin Community College, Team 13-1, Watkins Fall 2022 Mitglied von Austin Community College, Team 13-1, Watkins Fall 2022
AUSTINCC-WATKINS-F22S13G1
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 158
