Zum Hauptinhalt wechseln
PowerA Fusion Controller For Xbox One Headphone Jack Replacement
Was du brauchst
  1. PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 3 PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 2 von 3 PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 3 von 3
    • Remove the (9) nine 9.2mm screws (circled in red) with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
    Frag FixBot
    Kommentar hinzufügen
  2. PowerA Fusion Controller For Xbox One Headphone Jack Replacement: Schritt 2, Bild 1 von 2 PowerA Fusion Controller For Xbox One Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Remove the (2) two 9.2mm screws (circled in red) with a JIS #1 screwdriver.
    • Remove the back cover of the controller as seen in image (2) two.
    Frag FixBot
  3. PowerA Fusion Controller For Xbox One Headphone Jack Replacement: Schritt 3, Bild 1 von 2 PowerA Fusion Controller For Xbox One Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Desolder the soldered joints that are connecting the headphone jack to the motherboard (Circled in red).
    • This guide will show you how to solder and desolder connections.
    • Remove the headphone jack and put it aside.
    Frag FixBot
Abschluss
Andrea
668 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S14-G4, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Mitglieder
7 Anleitungen geschrieben
2 Kommentare zur Anleitung
Has this been proven to work? Thanks!
Luis Lujan - Antwort Teilen
real help full its like having a broken down car and a video online saying “open bonnet and fix car” no mention of where you can get those parts ie the most important bit the parts ie the female jack port !!!! other than not for sale !! blinding
James Price - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 48
Insgesamt: 8,157
