Zum Hauptinhalt wechseln
PowerA Spectra Controller Buttons Replacement
Was du brauchst
  1. PowerA Spectra Controller Buttons Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Flip the controller over so the backplate is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. PowerA Spectra Controller Buttons Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
    Frag FixBot
  3. PowerA Spectra Controller Buttons Replacement: Schritt 3, Bild 1 von 1
    • Hold the front case in one hand and pull the rear case off.
    Frag FixBot
  4. PowerA Spectra Controller Buttons Replacement, Buttons: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
    Frag FixBot
  5. PowerA Spectra Controller Buttons Replacement: Schritt 5, Bild 1 von 1
    • Pull the motherboard away from the controller to access the buttons.
    • The motherboard is not fully removable because it is attached to the D-Pad. Be careful not to rip the motherboard from the D-Pad.
    Frag FixBot
  6. PowerA Spectra Controller Buttons Replacement: Schritt 6, Bild 1 von 1
    • Pull the old buttons out of the shell of the controller using the angled tweezers.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 260
