Zum Hauptinhalt wechseln
PowerA Spectra Infinity Enhanced Faceplate Replacement
Was du brauchst
  1. PowerA Spectra Infinity Enhanced Faceplate Replacement, Motherboard: Schritt 1, Bild 1 von 2 PowerA Spectra Infinity Enhanced Faceplate Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Flip the controller so the back is facing up.
    Frag FixBot
  2. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
    Frag FixBot
  3. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 3, Bild 1 von 2 PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 3, Bild 2 von 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
    Frag FixBot
  4. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
    Frag FixBot
  5. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 5, Bild 1 von 2 PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 5, Bild 2 von 2
    • Use your hand to separate the motherboard from the face plate.
    Frag FixBot
  6. PowerA Spectra Infinity Enhanced Faceplate Replacement, Faceplate: Schritt 6, Bild 1 von 1
    • Remove the buttons from the face plate (d-pad, action buttons, start/select, etc).
    Frag FixBot
  7. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 7, Bild 1 von 1
    • Remove two 10 mm screws holding the bumper to the faceplate using a Phillips #0 screwdriver.
    Frag FixBot
  8. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 8, Bild 1 von 2 PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 8, Bild 2 von 2
    • Remove the single 7.9 mm screw holding the bumpers to the faceplate using a Phillips #0 screwdriver.
    Frag FixBot
  9. PowerA Spectra Infinity Enhanced Faceplate Replacement: Schritt 9, Bild 1 von 1
    • Use your hand to separate the faceplate from the bumpers.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 6-5, Botvin Spring 2024 Mitglied von UMass Dartmouth, Team 6-5, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 36
Insgesamt: 602
