Was du brauchst
Detach the cover/serving bowl from the popper.
Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
Removing the bottom cover exposes the internals of the popper. The base holds together the centrally mounted motor and the wires for the power cord and heating element.
Remove the two black wire twist caps, and unwind the different wires.
Remove two more 14 mm Phillips #2 screws attaching the white plastic holding the wall cord to the base.
Remove the two 14 mm Phillips #2 screws from the motor.
Remove the motor from the popper.
