Einleitung
This guide will show how to replace one of the controller buttons should they become inoperative. Soldering is a skill needed to complete this action. The button being replaced is 6mm x 6mm x 9mm.
Was du brauchst
Remove the single 6.5mm Phillips #1 screw from the battery cover.
Remove the three AAA batteries.
Remove seven 6.5mm Phillips #1 screws from the back panel.
Pull the back panel up to separate it from the front panel.
Remove three 4.5mm Phillips #1 screws from the motherboard.
Pull the motherboard out of the case.
