Einleitung
This guide shows you how to replace the motors on your drone. Soldering is a skill required for this task. Replacement motors can be found on the manufacturer's website.
Was du brauchst
Remove the blade guards by pushing the guards downward towards the padded feet.
Use the flat end of a spudger to pry apart the the two pieces.
Lift the back panel up to separate it from the front panel.
Fast fertig!
Abschluss
