Einleitung
The Terracopter EVO controller motherboard is used to control all of the functions of the controller and relay them to the drone.
Was du brauchst
Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
Remove the battery cover from the controller.
Schritt 3 Protocol TerraCopter EVO Controller Opening
Achtung: Die Schritte 3-4 stammen von einer Anleitung, die derzeit bearbeitet wird.
Orientate the controller to where the battery compartment is facing upwards.
Remove the four 5mm and four 4mm Phillips #1 screws from the case.
Since the battery wires are still attached, carefully move the rear panel down to expose the motherboard.
Remove the eight 5mm Phillips #1 screws from the motherboard.
Locate the set of four green wires and one black wire attached to the motherboard.
Remove the male, white connector by pressing up on the two tabs on the female connector. Then, pull the connector away from the female connector on the motherboard
Locate the single pin holding the negative and positive wires to the motherboard. Each lead should have one pin holding each wire to the green side of the motherboard.
Using a soldering iron, melt the existing solder point for the red lead (positive line).
Using a soldering iron, melt the existing solder point for the black lead (negative line).
Pull the red and black leads through their respective holes, out of the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
