Zum Hauptinhalt wechseln
RCA RCT6272W23 Battery Replacement
Was du brauchst
  1. RCA RCT6272W23 Battery Replacement, Case: Schritt 1, Bild 1 von 2 RCA RCT6272W23 Battery Replacement, Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Battery Replacement: Schritt 2, Bild 1 von 2 RCA RCT6272W23 Battery Replacement: Schritt 2, Bild 2 von 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
    • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Battery Replacement: Schritt 4, Bild 1 von 1
    • Next, use the spudger to pry the battery off of the rest of the body.
    • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Michigan Tech, Team 1-5, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 5,317
