Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If you notice your battery life deteriorate, or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
  1. Back Cover
  2. Battery
Use this guide to replace the battery of your RCA RCT6378W2.
  1. Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet. Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet. Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
    • Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
  2. Remove the back cover with a plastic opening tool, exposing the battery and motherboard. Remove the back cover with a plastic opening tool, exposing the battery and motherboard. Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
    • Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
  3. Remove the two black tape strips from the battery pack. Remove the two black tape strips from the battery pack. Remove the two black tape strips from the battery pack.
    • Remove the two black tape strips from the battery pack.
  4. Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers. Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers. Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
    • Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  5. Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  6. The new wires must be soldered back into place on the motherboard at the original location. For tips on soldering techniques, see this Soldering Guide. For tips on soldering techniques, see this Soldering Guide.
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide.
Abschluss
12 weitere Nutzer haben diese Anleitung absolviert.
Justin
425 Reputation
2 Anleitungen geschrieben
Clemson, Team 14-4, Shirley Spring 2015 Mitglied von Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Mitglieder
15 Anleitungen geschrieben
Links on ordering replacement batteries
Great step by step instructions not for novices!
Robert Groffel - Antwort
i liked good job
Luis Orellana - Antwort
Can you give information about this battery?
What type of battery is it?
Is Applicable under the Dangerous Goods Regulations?
carlos - Antwort
where do i order the battery for RCT6378W2
Michael Giulian - Antwort
RCT6378W2 where can i get a replacement battery
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 5
Letzten 7 Tage: 32
Letzten 30 Tage: 154
Insgesamt: 22,623
