Zum Hauptinhalt wechseln
Razer Blade RZ09-0130 2015 Fan Replacement
Was du brauchst
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: Schritt 1, Bild 1 von 2 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 2, Bild 1 von 2 Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: Schritt 3, Bild 1 von 2 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 5, Bild 1 von 2 Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 5, Bild 2 von 2
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 6, Bild 1 von 3 Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 6, Bild 2 von 3 Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 7, Bild 1 von 1
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: Schritt 8, Bild 1 von 1
    • Repeat the preceding steps to remove the second fan.
Abschluss
Tyler Clayton
183 Reputation
1 Anleitung geschrieben
Cal Poly, Team S18-G1, White Winter 2020 Mitglied von Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 609
