Zum Hauptinhalt wechseln
Razer Blade Stealth 2016 Motherboard Replacement
Was du brauchst
  1. Razer Blade Stealth 2016 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Razer Blade Stealth 2016 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Razer Blade Stealth 2016 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Motherboard Replacement: Schritt 2, Bild 1 von 2 Razer Blade Stealth 2016 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Motherboard Replacement: Schritt 7, Bild 1 von 3 Razer Blade Stealth 2016 Motherboard Replacement: Schritt 7, Bild 2 von 3 Razer Blade Stealth 2016 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare zur Anleitung
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Matias Urani - Antwort
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
Sarah Westberg -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 30
Insgesamt: 1,018
