Einleitung
After extensive use or a large period of time, the Razer Deathadder Essential’s (Model Number: RZ01-0254) mouse buttons may begin to double-click. Double-clicking is when the user only gives one input but receives 2 outputs.
In this guide, I will show you how to replace the buttons so that they will be brand new!
Before getting started, if you are unfamiliar with how to solder and desolder components from a motherboard, please read this guide.
Was du brauchst
Use a spudger or opening tool to remove the top skates from the mouse.
Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
