Einleitung
Before accessing the speaker casing, you need to remove the ear cushion. The casing of the speaker could be damaged by dropping the headset, but can easily be replaced by following the steps provided. The wires will have to be soldered during the reassembly process.
Was du brauchst
Pull the ear cushion away from the speaker by sliding down to release the cushion from the plastic covering.
Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed.
Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
Cut both wires connecting the speaker to the headset by using a wire stripper or pair of scissors.
Use the Phillips #00 screwdriver to remove all four 9mm screws.
Rotate the screwdriver counterclockwise when removing each screw.
2 weitere Personen haben diese Anleitung absolviert.
