Was du brauchst
Using an opening tool, pry off the the outer front plate.
Once the front plate is loose, pull it off.
Using an opening tool, pry off the the handle grips.
Once they're loose, pull off the handle grip plates.
Using an opening tool, pry off the Xbox logo plate.
Once it's loose, pull off the Xbox logo plate.
Remove ten 9 mm screws from the controller using a Phillips #000 screwdriver.
Using an opening tool, pry off the backplate of the controller. It should come off relatively easily.
